Old 28th January 2013, 09:53 PM
Default Lumbar support deflates slowly....
Is there a "quick fix"? FL S8 leather Recaro seats.
Old 28th January 2013, 09:57 PM
Nope... its a seat apart job. Its not common as such, but I had my first FL a8 fixed under warranty for that, and I've heard of at lease one other case. The valves that hold the air leak, and it goes down.....
Old 28th January 2013, 10:01 PM
I'll live with it. Don't normally use it, was just checking round everything.
Or is there some sort of lubricant you can spray into the "air intake" (wherever that is) that will lubricate the valves so they work better?
Old 21st November 2014, 11:09 AM
I saw Gorans' picture of a seat somewhat disassembled. Based on that Goran, is this definitely a dismantle job or is it in any way accessible in the car?
Old 21st November 2014, 12:58 PM
I cant say for sure. Theoretically, if you can unhook the middle backrest cushion insert you will have access to the lumbar support mechanism and then you can fix or replace it.
The tricky bit will be getting to the hooks without damaging the backrest insert as you slide your hand behind it. The easiest option may be to unhook the bottom hooks first then lift up the insert from the bottom gently to try to get better access to the middle and top hooks.
Apologies about the seat headrest, I kept thinking its the front seat.
The back seat backrest is fairly easy to detach and angle back so you can see behind it, is the headrest mechanism obvious and accessable when you do that or is it buried inside the seat foam?
Unfortunately both my back seat backrests (I have a spare one of those too ) are the basic non adjustable kind.
Old 21st November 2014, 01:17 PM
No problem, I didn't realise until your last picture that we were talking at cross-purposes.
I think that while it's only a handful of screws, it's a two-man job to left the rear backrest off its fixings so I haven't tried.
Back on the lumbar support, that works, but deflates slowly so I presume there's a leak in a non-return valve somewhere around the pump. I have no idea where that is in the seat unless it's all integral with the actual inflatable bit - I would expect it to be elsewhere and joined by pipes, but....
