Old 29th January 2013, 04:50 PM
wheel spec is 8Jx18 ET45 5/112mm
The S8 wheel spec is ET48 so only 3mm difference in offset. The S4 wheels will stick out slightly further (will still be well within bodywork though)
So they will fit? I'm not even sure what the offset is? My main concern is fitting over the calipers on the front
Old 29th January 2013, 04:54 PM
They should be fine, but you'll only know for sure when you try one.
The smaller offset means they're further out, so 3mm MORE clear of the caliper.
Also, that style of wheel has spokes further out than the PF Avus, which I've just bought a set of for winter wheels, and they clear fine.
(you might just see that in the picture below - PF 18's in front, FL behind with the larger calipers)
Old 29th January 2013, 06:16 PM
Thanks, I'll take a punt
