Old 10th February 2013, 01:20 PM
Reffro Reffro is offline
Hi, the screen in the S8 was the second replacement screen I had done during my ownership. Both we were fitted one of the national companies. The work was done to a good standard each time, just make sure you get them to pack out the gap at the base of the screen with foam.
Old 25th February 2013, 09:52 AM
I used Glasstec on reccomendation form Pistonheads. He did a good job in my opinion, didnt damage anything, knew how to take trim off an put it back on, used a cork/rubber block thingy at the bottom of the screen. that was 2 year ago, 2 winters later still no squeaking, leaking, etc.
http://www.glasstecauto.co.uk/
p.s. if yours is a heated windscreen, they may damage the conducting strips which go all the way round right next to the silicon seal that has to be cut through. May be a good idea to tell them to be careful or get a spare if you want to replace it with another heated screen. (I just went for non-heated so took the conducting strip out).
