Old 27th February 2013, 08:13 PM
green A8 green A8 is offline
On a serious note, the scuttle drains are certainly a good place to start asThe Laird suggests. The car has been stored outside for along time and if water has accumulated there, it will soon start to affect electrical stuff.
Thanks for those suggestions.
All the scuttle drains have either been removed or cleaned out I removed the entire ECU box in my hunt for 'Botangs hole' Everything was surprisingly dry and corrosion free all things considered. I also removed and cleaned out the air con drains at the same time. The only major part I replaced in the ECU box was the cruise control module/ecuas some of the pins had minor corrosion. The car was running without any prooblems before I removed and charged the battery, it's got me beaten! In the morning I'll be testing alternator output (if there is any) The charge light is more of a concern to me. If I have to replace a bulb fair enough, but if it's a LED that's gone south that's uncharted territory for me
Another odd thing that I forgot to mention earlier, the heater motor continued turning slowly with the ignition turned off and the key out of the car. Not right surely?
