Old 4th March 2013, 07:47 AM
Problem has re-occurred. When I went out to check on my work, the strip(probably due to warmth from the sun) had popped off again and now will NOT re-seat on the clips at all. The only cure i think is to drill the trim at both ends and put two stainless, self tapping screws into the bumper. It will of course be visible. Has anyone any suggestions befoe I go down this route?
Old 4th March 2013, 08:10 AM
New clips from Audi and pop the bumper off perhaps? If you order them, I can pick them up on the way home. I'll give you a hand at the weekend if you like
Old 4th March 2013, 08:41 AM
thanks for the offer Jim. Will pm you.
Old 12th March 2013, 08:28 AM
I have now got new clips which do seem (being new) more resilient and "springy" than the old ones. So I am now waiting for aday when its warmer and not snowing to try and fit the clips and trim. In the meantime i stripped and polished the trim piece to try and remove the marks, pitting, scrapes and deterioration of the finish on the basis that I couldnt make it look worse. Started with wet&dry 800 and finished with 3000. Applied 2 coats of clear laquer. It certainly looks a lot better though I couldnt remove all the pitting. I dont know how long it will last with that protection. Anyone any experience?
