Old 17th March 2013, 08:45 PM
Hi I'm not a 100% sure but i think it's there to make bleeding easer, otherwise the pedal sticks down and you have to try and hook your toes under it to lift it back up! (Bled a clutch yesterday and it stuck down and it was a pain)
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1992 Mazda eunos v spec
1976 Reliant Kitten
1965 Porsche 911
Old 18th March 2013, 06:50 PM
thanks, I'll try to keep the spring in that case. At least it sounds like its not critical for actual braking.
Old 18th March 2013, 07:17 PM
Great work guys. The first RHD 6 speed manual is just around the corner.
Old 19th March 2013, 06:58 PM
Thanks Mike, I am really desperate to complete this now after 4 year of waiting.
We also need a aluminium-welding expert to weld these together for us.
I'm still not sure what material to use for the clutch pedal, I'm thinking Audi used aluminium for a reason. Although dont some A4's and A6's use a steel pedal?
Old 19th March 2013, 07:13 PM
message/talk to alex - username vwalexjoy on here goran
he is based in Bristol but I know he can Tig Weld Aluminium, its part of what he does for a living if you need his mobile then pm me
Old 20th March 2013, 04:29 PM
You can MIG weld ali but you need argon gas and obviously ali wire. TIG will be the way forward for you.
Old 20th March 2013, 05:05 PM
I guess not very well with regular MIG as MIG is constant voltage but TIG constant current, also not any TIG is suitable for aluminium, you need high frequency AC TIG to do good quality welds on aluminium.
Old 20th March 2013, 08:42 PM
I may be able to help with the welding if your any where near oldham! tig welding is one of my hobby's
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
Old 21st March 2013, 10:01 PM
Thanks Dave I may take you up on that offer although I am far away from Oldham (down in Kent). I just need to shape this bracket for the master cylinder and over-centre spring.
Looking at one of the spare pedal boxes I have, looks like I could chop one of those up, as all thats really needed is a angle shape to provide support.
I'll keep chopping away and let you know what I come up with.
Neil thanks for your suggestion too.
Old 21st March 2013, 11:13 PM
Mmm Kent is a bit of a mission! may be easer to post it!
Dave
2003 A4 avant TDi
1997 Volvo V40 2.0T
1976 Reliant Kitten
1965 Porsche 911
