Old 2nd April 2013, 11:24 AM
HPsauce HPsauce is online now
Where would a wooden wheel come from, it's certainly not an option in my late 1998 PF price list?
Old 2nd April 2013, 11:27 AM
Wasnt available on PF - Check FL pricelist...
Old 2nd April 2013, 11:41 AM
Sir WIll Sir WIll is offline
If anyone has a scan or a PDF of A8 price lists I would love a copy
Old 2nd April 2013, 02:59 PM
Ah yes, I forgot about that most noteworthy car, which I have seen in the flesh (commence backpeddling on comment about never seen one)
Noteworthy as it has horrifically expensive Factory PF D2 Sat Nav option, and wooded wheel and no other options that I recall - Not even heated seats... Still. Cheaper to retrofit heated seats than the Sat Nav
didn't it have self levelling rear suspension too? tsk tsk Ian, your memory is going!
Old 5th May 2013, 10:12 PM
Default An Update
I've finally got some bits done on this motor:
  • AC Regass which made a massive difference
  • New B&O Speaker which fixed all the annoying fluff
  • Sorted out some trim on the parcelshelf that was untidy
  • Replaced the Black Mesh on the dash which was marked
  • Replaced the Analogue TV tuner with Digital
  • Fitted AMI
  • Sorted broken rear caliper
  • Replaced headlight bulb
  • Fitted new MMI Console buttons
  • Fixed broken rear view mirror
  • MMI Upgrade to latest version for better B&O and AMI support
Few more bits to do, but getting there......
Old 6th May 2013, 06:44 AM
Does it surprise you that such a nice spec car was allowed to get into the state it did? Certainly does me - makes you wonder if they just didn't care because the money wasn't an issue or they couldn't afford to look after it as intended
Sounds like it'll make a lovely buy when it's all sorted
Old 6th May 2013, 08:24 AM
It is an odd one for sure. It certainly has its fair share of niggles, unaided by the fact that my keen eye spots every single one of them and just has to sort it
Lets not forget, that the previous owner probably looked at every one of these jobs as being cost prohibitive, but a little DIY and a few calls to a8parts and she's getting ship shape very cost effectively
Old 5th August 2013, 02:36 PM
So, got quite a bit more done, mostly thanks to David @ a8parts I might add:
* Full service, oils, filters etc
* Full gearbox oil flush
* Autoboot sorted and fully working now
* Wheels all refurbished, balanced and looking mint
* Broken Rear view mirror replaced
* New Discs/Pads all round
I've never spent so much attention to servicing 1 vehicle......
The gearbox flush has made an incredible difference to a box that wasn't feeling bad to start with..... MPG is definitely up as a result and gear changes are incredibly smooth now with only a slight dip in the engine tone to denote a change through the gears.
I've notched up 8000 miles in it, and for once, I'm absolutely stumped as to what to 'upgrade' to. This car is verging on perfection for my mainly-motorway driving habits and any other D3 varient would never be able to tread in these footsteps and leave a good impression.....
Old 5th August 2013, 05:52 PM
gninnam gninnam is offline
Glad it's doing you proud
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 5th August 2013, 06:18 PM
If it's your perfect spec and everything major keeps working you may as well keep putting on the miles with a smile on your face
Presume at some point the D4 might become a tempting proposition?
