I am having some issues with losing settings when powered off.
When I turn the key on in the morning the MMI language is at the default German. The battery condition is showing around 10% on the car settings, yet there seems to be plenty of life to crank the engine, starting is not a problem. There is a battery in the boot on the right hand side. This measures around 11.5 volts. Is this the only battery or is there another battery somewhere? |
No other battery... Have you updated the MMI to the latest version?
Can't remember if this was a known bug, or if it was a fault, but I do recall seeing a similar issue before somewhere.
How do I update the MMI version?
2004 A8 4.0TDI Quattro ![]() |
You need to get hold of the disks.. take a look at this thread for where you might find them..
http://forum.a8parts.co.uk/showthread.php?t=6483
Tags |
battery |
