battery is new in the last 2 months
the wheels mystery continues, the spare is audi 4D0 601 025 AE which is a 20" and from a google search suggests S8 fitment but the design is different to the FE ! suspect I'll end up trying to source a set of 18's all round |
![]() regarding the useable all year round bit - the grippiest car I've ever owned (apart from my Mk5 R32) was in fact ....... the M3 CSL. Astonishing and more than comfortable keeping up with a well driven RS4 across 650 miles of Scottish roads driving a few years back. That CSL will stay with me for the rest of my life - incredible car. But if it snows ...... forget it ![]() But onwards and upwards - I'm still smiling after pushing it a bit on the way home last night, haven't driven the car today but I have just fitted a new pair of 66240 Osram D2S (definitely fresher than the old ones and look like a better design) and the Aerotwin wipers (instant improvement and much smoother across the screen) just had confirmation that rear calipers, fluid change, engine temp sensor & speed sensor are all being done next Wed at my trusted place (APS in Brackley) ![]() |
well today I've asked the car to deliver a safe 320 miles round trip to North Wales and back ........ and it's been faultless.
Comfortable, fast when needed, economical for what it is and has been a real pleasure to drive. A few things I'm starting to think need some tinkering with - definitely the tyres, that is in hand - but I'm looking at some Bilstein B6 to replace the OEM shocks and boy does this car need a Milltek cat-back ! I run the Bilsteins on my Golf and they are spot on with the OEM springs - hopefully this will also be the case on the S8. However need sell my E39 first, then there is budget available to freshen the suspension and give the car a proper voice ! A quick question - would I be sensible to do front top-mounts if replacing the shocks all round ? Also does anyone else get the drivers side plastic panel under the bonnet (closest to windscreen) rattling away ? Bloody annoying. Oh and the wipers now actually work since fitting the aerotwin blades, but they are still terrible ![]() ![]() |
For wipers give yourself a favour and order Audi genuine SWF wipers. They are the best available. Audi part numbers: 4B0 955 425 and 4A0 955 425 B. Refresh wiper arms too if they are rusty, missing some elements or twisted. Wiper arms are still available from Audi. In future you can buy SWF rubbers which are very easy to change without any tools required. Rubbers are the same for right and left sides, part number 895 955 429 A.
>> Also does anyone else get the drivers side plastic panel under >> the bonnet (closest to windscreen) rattling away If you're talking about scuttle panel it should be normally very well attached. If you'll plan to replace wiper arms it will be easy to remove scuttle panel when wiper arms are out and inspect it. I personally never had a problem with it. Scuttle panel has rubber strip and should adjoin windscreen without gaps.
I'd rather drive on left |
well after a couple of hours effort I cannot find the rattle so far. Had the panel off that covers the wiper motor on the drivers side, found that the lower windscreen trim wasn't properly fitted - fixed that but no joy with the rattle. It's not the cover panel itself as still does it with that off the car.
Then had the lower dash off below the steering wheel, whichever feckin monkey fitted a phone kit previously needs shooting as they broke half the fixings putting it back together and did a pretty poor job all round. So need to order some new bits at some stage to put that right. It really pees me off when "professional" fitters do this and the owners are probably none the wiser. grrrrrr ![]() |
I feel your pain. Real professionals are extremely rare.
Can't help with rattle. Rattles are deceptive. I can only say that usually rattle comes from completely different location than you expect. Try to cross check with passenger.
