Old 23rd June 2013, 04:06 PM
If car is not a weekend / owner meets toy I'd suggest to go for 18' genuine Audi alloys. I personally like this ones:
And I'd suggest to buy 245/50 R18 tyres. They are taller then stock 245/45 R18. Will fully occupy wheel arch.
20' tyres are expensive if you go for right stuff like Michelin. And it'll be recurring annual expense as hi performance tyres will wear out quickly. Plus, you'll get tired to change suspension as 20' are much rougher ride.
Old 23rd June 2013, 06:40 PM
I'd go for either H&R or Eibach hubcentric spacers. They are superb quality and you won't need to buy more wheel bolts as most of them bolt to your hub then you use your normal wheel bolts to bolts the wheels on.
With 8.5" wheels I would go for 20mm spacers per side at the rear and 15mm per side at the front which will space things out nicely
linky to hubcentric spacer site
Old 23rd June 2013, 06:45 PM
Davie b Davie b is offline
Thanks mate ,
what size tyres should I go for
Old 23rd June 2013, 06:48 PM
Are you going for 20" wheels?
Link to spacers site - http://www.performancealloys.com/all...PCDID=12&tab=3
Old 23rd June 2013, 06:52 PM
Yes mate
Old 24th June 2013, 03:40 PM
S4_Sat S4_Sat is offline
I'm fitting a set of 20" alloys to mine. They were on the car before but they're being refurbed in shadow chrome with stainless bolts. They're 10"x20" at the back with 275/30/20 tyres and 8.5"x 20" at the front with 245/35/20 tyres. The alloys I have are 5x114 so will be using wobble bolts to make them fit.
