Installation program doesn't seem to work with vista...
Looks like I need to dust off the old XP laptop to use this one
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten |
You tried running it with Admin rights?
I have to do that with the PhatNoise software (amongst other things).
Assume you are running Vista, Have you tried compatibility mode?
Runs fine on XP
can't be ar$ed mucking around with Vista
so, anyone worked out where the original firmware files live...?
I have them Clive, think someone also posted them somewhere in this thread.
I just need to work out compatibility mode now as my lappy is vista, then work my way through the Deutsch, got an F at school
Could help you, if it wasn't that late.
Gotta go to bed... ---------------- Now playing: Billy Talent - The Dead Can't Testify via FoxyTunes
Audi S8 manual, 1996 <- much fun Kawasaki ZX9-R 2001 <- much more fun always remember:ficken! |
Any help is welcome!
I am assuming that the current firmware, which is in the device's memory, is also located on the nav disc.
I then assume that it is this file that is opened with the Kolumbia program. Presumably once loaded the program opens the rest of its features so that you can add a different splash screen and then save the file. I'm then assuming that this file then has to be burnt to a CD so that it can then be loaded into the satnav unit's memory. Did I get any of it right...?
Maybe..?
It told me to insert a CD, I thought it was just going to be through a VAG COM cable..
The firmware definitely has to be updated from a CD - I did this with the S4 satnav (RNS-D too), but that was to update new features which weren't in the original firmware.
RNS-D firmware is a seperate CD (had a look but couldn't find a download). It's only the DVD-based nav units which have the firmware on the disc.
