Old 23rd July 2013, 06:52 PM
Welcome back!!!
Looking forward to seeing it at the next meet. Saving another D2 thats a noble cause.
Old 23rd July 2013, 10:57 PM
Thanks, Goran. I'm quite happy with it, not only has it had the belts done, and a new gearbox fitted but all the toys work too, it has been really well looked after all it's life, featured on TV and also it was an Audi UK car, so potentially a press/management car.
Adrian, the owner has changed the following.
- New crank sensor
- New cam sensor
^^ £800 in parts alone from Audi, apparently, and that didn't solve it!
Also, a new fuel pump and assembly.
I believe it is wiring to or the ignition switch itself.
We did get it to turn over and run for about 5 minutes, and then it started chocking as if it were being starved of fuel (half a tank in there). My theory is the fuel pump hasn't been fitted right and it isn't picking up the fuel from the tank, I've noticed the fuel pump fuse has blown, would a faulty relay do this, or is it more likely to be wiring/badly fitted pump? I'll replace the ignition switch, fill the tank, and go from there...
It'll be fun anyway, it's only a nightmare when you rely on the car, and of course, I have my DS and RS, plus use of the D4 if I really need an '8 fix, it ain't no D2 though...
Old 24th July 2013, 07:15 AM
After i had my fuel pump done by the garage it would cough and splutter at around half a tank and the cut out, and it was the assembly not fitted properly, still scared to run her too low but i haven’t had it die on me since i spent a day in the boot swearing at how rubbish a design it is. So could well be the pump.
Empty a 20L jerry can in it and see if it runs.
Old 24th July 2013, 08:15 AM
Will give that a go, Dezzy. That wouldn't cause the fuel pump fuse to blow though, would it?
Old 27th July 2013, 07:48 AM
CliveH's Avatar
CliveH CliveH is offline
Welcome back Amar
(Not as if I'm a regular anymore myself but still like to pop in from time to time to see what's going on )
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Dave McB Dave McB is offline
I had mine do that before the fuel pump chucked it - apparently they need programmed properly. The pump will cut out if the ECU thinks the fuel tank is empty. It needs reset with a 1/4 tank of fuel in it
Old 24th July 2013, 08:22 AM
If the pump isn't installed properly and runs dry then it can draw too much current for too long and burn out the fuse.
Old 24th July 2013, 08:32 AM
This is my gut feeling. The only thing that made me doubt it was this garage have spent weeks and thousands trying to diagnose the fault and failed. I reckon the initial problem was the ignition switch, and now they've messed about with the fuel pump, I need to sort that too, where it was only the switch/wiring to begin with. Let's see. Thanks, Psyche.
Richy - Good effort, but that's a facelift.
Thanks, Dave. Will look in to what I need to do to calibrate via VAG COM, top stuff.
Old 24th July 2013, 08:51 AM
Depends on the kind of garage that did the work to date - if a main dealer they probably went for the 'well that doesn't work as intended so we'll change it for a new one and see if it fixes it' rather than following a logical fault finding exercise that'd probably cost more in labour than they could justify charging.
Potentially a day with a decent specialist would sort it if they can work through from first principles. To confirm the switch is duff you need to know which pin on the back should be doing what and at what time in the starting/running cycle
richyb66 richyb66 is offline
I can't find it listed under Silent Witness but given that there are 2 A8s together I wonder if Audi loaned out cars for this?
http://www.imcdb.org/vehicle_5749-Au...p-4D-1999.html
