Old 24th July 2013, 08:32 AM
If the pump isn't installed properly and runs dry then it can draw too much current for too long and burn out the fuse.
This is my gut feeling. The only thing that made me doubt it was this garage have spent weeks and thousands trying to diagnose the fault and failed. I reckon the initial problem was the ignition switch, and now they've messed about with the fuel pump, I need to sort that too, where it was only the switch/wiring to begin with. Let's see. Thanks, Psyche.
Richy - Good effort, but that's a facelift.
Thanks, Dave. Will look in to what I need to do to calibrate via VAG COM, top stuff.
