Old 31st July 2013, 09:20 AM
Thanks, Paul
The fuel pump relay is good, the benefit of having another identical A8 to swap bits and test has been particularly useful!
Could someone please get me elsawin instructions on how to change a fuel pump on a 1995 A8 4.2?
Old 31st July 2013, 12:21 PM
You need to sort out cranking issue first then. Double check the earth lead, connections at the battery and put battery on charge overnight.
Old 31st July 2013, 12:37 PM
Some pdf's from Elsa
Old 1st August 2013, 03:51 PM
Thanks for the PDF's Ainair, is it important to drain the tank? It has 3/4 tank of fuel in it, that's going to be a pain...
Old 1st August 2013, 04:08 PM
HPsauce HPsauce is online now
Just put it in the V10, that'll gobble it up PDQ.
Old 1st August 2013, 04:32 PM
No. I have done it twice and one time it was about 90% full and other about half full.
Old 4th August 2013, 10:54 AM
Ainair came out and fixed it for me yesterday, car now drives like a dream after the new fuel pump, thanks, Ainair - top work.
Old 4th August 2013, 01:50 PM
Nice one
You going to bring one of your fleet to AITP next weekend?!
So was it just the pump incorrectly seated in the end or other related issues not helping?
Old 4th August 2013, 02:14 PM
I will let Ainair answer that one, I wasn't at home when he worked on the car, and as I've been busy I've had no real chance to speak to him.
Loving the instant non drive by wire throttle response, and the lovely naturally aspirated V8 power delivery, it's so smooth, and no matter how much you floor the throttle, it won't feel violent like an S8 might, I've always loved the PF D2 A8 4.2 power delivery/setup.
The owner still hasn't found the V5, and the V11 reminder he gave me is two years old... So can't tax it until that's sorted, so AITP is probably likely to be in the RS6, if I come at all as I am mega busy.
Old 4th August 2013, 03:11 PM
You might as well apply for a reg document yourself - it'll take a few weeks and you won't be able to tax it till after the reg document arrives anyway.
V5s tend to be lost for good unless they suddenly remember where they left it
