Old 4th August 2013, 04:10 PM
Well fuel delivery unit definitely has been replaced before, there was a (stock) number painted on it, there was also unusual level of corrosion on pump terminals and filter mesh. So I would say that it has been in storage for a long time or in unsuitable environment which caused corrosion. My best guess would be that pump inside was corroded as well which caused it to work sometimes and not others and also introduced extra resistance and caused it to draw extra current blowing fuse. When I got to it it was open circuit, probably burned motor coil because of extra current flowing through it.
As far as taxing goes you can go to local DVLA office and tax it straight away as long as you have insurance and MOT. You will need to apply for new logbook at the same time and if you have not got green slip from old logbook it will cost you £21 extra. V5 or taxing is not a proof of ownership. V5 is for registered keeper, it does not prove ownership, if anybody is happy to take responsibility and pay tax DVLA does not have anything against it.
Old 4th August 2013, 04:35 PM
Have they relaxed it in recent years? I can recall it being a major pain in the bum when they introduced continuous registration and taxation when buying at auction as no reg doc basically meant parking the car up until the reg doc arrived back with you before you could then tax it
Good news it's sorted - did the pump etc get replaced again with a new one this time?
Old 4th August 2013, 09:15 PM
First time I did it was about 8 years ago and I know somebody who did it last summer.
Yes brand new genuine VDO pump went this time.
Old 4th August 2013, 11:34 PM
Absolutely. I won't cut corners. I'm even going to change the brand new budget tyres on it for proper ones. If the ex owner had fitted a new pump the first time himself, he wouldn't have had to sell the car off as a 'non start spares and repair'.
Old 5th August 2013, 06:15 AM
Makes you realise how easy it is for otherwise perfectly good cars to end up getting broken for spares due to a badly diagnosed or repaired fault.
Old 18th August 2013, 08:41 PM
Bit of back to back driving with its younger brother today. Including a drag race.
Guess which was quicker?
Old 18th August 2013, 08:45 PM
Its looking very nice Amar, now you can roll up to the next meet in a D2
Old 18th August 2013, 08:52 PM
Reffro Reffro is offline
Easy it will be the D4... torque and an 8 speed gearbox will see to that.
