Old 5th August 2013, 09:30 AM
Dave McB Dave McB is offline
Default Delimited?
I understand its a bit of a pain to get a d2 S8 delimited
anyuone had it done yet, can you manage it with VAGcom or alternatively, where can i get it done?
Old 5th August 2013, 09:41 AM
My old PF S8 was delimited by the owner before me.
It involved replacing a chip, so programming AND soldering.
I even inherited (and hopefully passed on) the actual chip that was removed!
Old 5th August 2013, 10:13 AM
Depends if it is PF or FL. Either way the software in the ECU should be modified it's just that in FL it can be done through OBD but on PF soldering job only. Or just cut the speed signal wire from instrument cluster
Old 5th August 2013, 11:56 AM
I wouldnt get too excited.... It takes a heck of a lot of flat tarmac to get the S8 to 155mph, unless you're a regular autobahn stormer or have your own private airstrip I think it would be a complete waste of time tbh.....
Old 5th August 2013, 02:20 PM
its an 02 so its FL model.
Reason for enquiring was that, having been on the Autobahns & the Nurburgring earlier this year, i fancied going back.
My old S8 would be a great car for making the trip.
Working in the motor trade means that iv got access to plenty of diagnostic software, and wondered if it had to be VAGCOM or if any decent quality diagnostic computers can do the job.
I had also wondered which option to go into to remove the TV-in-motion restrictions
Old 5th August 2013, 04:52 PM
Reffro Reffro is offline
Or do like me and a couple others did and get the Revo map put on it. That removes the limiter at the same time. I had a GPS measured 158mph out of my S8 and it was still pulling hard enough to convince me 170mph was possible.
