Old 5th August 2013, 10:05 AM
RallyQuattro RallyQuattro is offline
instrument cluster which then passes processed speed signal to ECU, ABS, cruise control, gearbox, radio, climate control, servotronic steering, satnav , ect.
Do you have any idea where I can find one of these cables?
Owns at the moment:
S8-97 biturbo = RS8 My new trackday car
A8-94, A8-96, A6 1.8tq -2004
2 Urquattro 20v-90 one red, one blue,
and one old Urquattro ex rallycar,
and some other cars..
Old 5th August 2013, 10:18 AM
Looks like signal comes in the instrument cluster on pin 24 on the red connector and goes out the same connector:
ECU pin 19
gearbox pin 9
ABS pin 13
and pin 23 for everything else ( radio, climate control, servotronic, cruise control.etc)
Old 5th August 2013, 09:28 PM
If you want it easy there is always the GALA feed on the back of the Audio unit. It should be clearly marked on the radio......
Its not as frequent a pulse as the ABS generated ones though iirc, but might do depending on what you need, its designed to alter the volume of the radio as speed changes to compensate for road noise etc.
Old 6th August 2013, 07:16 AM
ECU pin 19
gearbox pin 9
ABS pin 13
Perfect
On my red contacts I have these colors:
Pin 19 green / white
Pin 23 White / Blue
Pin 24 yellow / white
So now I just have to find out where these wires go.
I will start to look for 19 and 23
Owns at the moment:
Old 8th August 2013, 07:32 AM
ECU pin 19
gearbox pin 9
ABS pin 13
Engine harness is a separate harness that I don't have anymore so do you know which connector pin 19 green / white cable goes to before the ecu ?
And do you know which connectors I can find Pin 23 White / Blue cable in?
Owns at the moment:
Old 8th August 2013, 10:42 AM
One of the wires from pin 23 goes to radio black connector pin 1, wire colour white/blue. Others will need some more digging to find out.
On cruise control its also white/blue wire, pin 9
