Old 5th August 2013, 09:28 PM
If you want it easy there is always the GALA feed on the back of the Audio unit. It should be clearly marked on the radio......
Its not as frequent a pulse as the ABS generated ones though iirc, but might do depending on what you need, its designed to alter the volume of the radio as speed changes to compensate for road noise etc.
