Old 17th August 2013, 08:29 AM
Default Not looking good for you.
Had a look under the lid this morning and took some photo's.
The access can only be described on mine as impossible, the pictures show the end of the cable and lever arm on each latch , but honestly I have no idea how your going to get to them as bodywork, rad grille etc are all in the way.
Your only hope I think is to try and pull the cable splitter off via the driverside wheel well, if you can reach up behind the headlight and pull the cable that feeds into the splitter.
Gooduck
ID:	6536   Click image for larger version
ID:	6537   Click image for larger version
