Old 23rd August 2013, 02:40 PM
Think HPSauce had his done this week or last - hopefully will be able to say what the bill was, although it'll be with South East loading on labour rates!
Old 23rd August 2013, 02:56 PM
Yesterday in fact, got it back today.
BUT I had both the rear and drivers side leaking and the pan. AND I had the fluid & filter changed as well, which requires removing the exhaust/catalysts on an FL D2 S8.
Also had the middle and rear diffs topped up as they are seeping very slightly (not enough to bother fixing, just top up).
Loadsa labour so loadsamoney.
The seals were cheap enough, one was £12.44 the other £22.41 (+VAT).
And you might need the gearbox topping up, that's about £12 a litre.
Hour or 2 of labour maybe to get one wheel off, do whatever you need to to the drive shaft to replace the seal and put it all back, then check and top up the gearbox - I'm no expert!
Old 23rd August 2013, 03:01 PM
tomo9700 tomo9700 is offline
Thanks for that. Like you say 2 hours labour plus the seal it cant be more than £150 really? What do most places charge per hour i have no idea.
Old 23rd August 2013, 03:17 PM
Depends entirely on where you live and if it's a local garage or main dealer - anything from £40-140 an hour!
Old 23rd August 2013, 03:29 PM
You do really need someone who is familiar with the construction of the car.
I think I'm paying about £60/hr plus VAT for labour and they're a VAG specialist with all the tools and knowledge.
Old 23rd August 2013, 03:36 PM
Im a mechanic my self but i work on trucks and its fleet only so we dont deal with the public/prices. Id do it my self but with it being on the drive and not at work i really cant be arsed! id rather pay the £150+ for someone else to deal with the hassle locally.
Old 23rd August 2013, 06:32 PM
Be careful, the new seal has a lip, and requires the new type flange with a groove to accept the lipped seal. This was re-designed in recogniton that the old design was too prone to leaking.
I dont know if you can still get the old type seals. From my experience I went to a place that didnt know, and they stuffed the new-type seal into the old flange, which obviously deformed the seal. Needles to say it was leaking again within a year or so. Next time round I went to 4Rings in Dartford and they put in the new type output flange as well, which costs around £120.
This:
http://forums.quattroworld.com/a8/msgs/32544.phtml
and this
http://forums.quattroworld.com/a8/msgs/56848.phtml
