Old 24th August 2013, 10:51 AM
tomo9700 tomo9700 is offline
There was quite alot of smoke, more than enough to be worried as i was. so i just took the car of the ramp and headed home. No charge, i wouldnt of paid anyway as he hadnt really started it. The last owner did say it was the rocker cover but its a funny smell so it points to the shaft really.
Old 24th August 2013, 11:10 AM
Does anybody know wich oil i should order. Ive just ordered the seal for £13 and when i asked for the oil he said it was ATF. I thought it was different stuff?
Old 24th August 2013, 11:12 AM
It will depend what gearbox you have. Just get the proper appropriate ZF Lifeguard stuff, presumably you're topping up?
This is interesting if you have a 5HP box: http://www.youtube.com/watch?v=Si8HXqpgz9A
Old 24th August 2013, 11:42 AM
Just remember that there are 3 separate compartments for oil in the gearbox.
1.Gearbox itself that uses ZF Lifeguard 5 about 9.7l
2.Transfer box regular gear oil like GL4, GL5 80W90 about 0.7l
3.Front diff same as transfer box about 1l
If you are just looking to top up whatever oil leaked out because of leaking seal the you need regular gear oil. Also you have not said which of the output seals is leaking, is it one of the front driveshafts or rear output.
Old 24th August 2013, 11:50 AM
1.Gearbox itself that uses ZF Lifeguard 3
Which gearbox? I'm sure mine uses ZF-LG5.
Old 24th August 2013, 12:05 PM
Typing error, my bad, corrected now.
Old 24th August 2013, 12:09 PM
green A8 green A8 is offline
1.Gearbox itself that uses ZF Lifeguard 3 about 9.7l
Good point about there being three seperate oil compartments. Just a thought I wonder if anyone has photos or an illustration to point the OP in the right direction of where these gearboxes leak from. I'd have thought there were at least three points. Front driveshaft seals (2) and rear propshaft/output seal (1)
I don't suppose it would be a bad idea to give some idea of where the all the fill/drain plugs are located either. Unless that's been covered by other threads.
At some point in the future I'll levitate one of my 8's on the ramp and take some photos.
Old 24th August 2013, 12:52 PM
Audipages has this on the rear output seal if it helps -
http://www.audipages.com/Tech_Articl...placement.html
Old 24th August 2013, 01:08 PM
Yes ive got that printed off the audi pages. Thats why i was asking wich oil it takes because the drive from the gearbox is sent to the transfer box first and its the transfer.box thats leaking where it sends the drive out to the propshaft. It will be the gear oil (2) as i cant imagine them sharing the same stuff.
