Well, here is teh output of teh auto scan
VCDS Version: Release 805.4 Data version: 20090602 Tuesday,21,July,2009,21:50:39:31144 Chassis Type: 4D - Audi A8 D2 Scan: 01 03 08 11 15 16 17 18 25 35 37 45 55 56 57 65 67 75 76 77 02 Mileage: 210180km/130599miles ------------------------------------------------------------------------------- Address 01: Engine Labels: Redir Fail! Part No: 4D0 907 557 P Component: 4,2L V8/4V MOTR AT D01 Coding: 04273 Shop #: WSC 00000 No fault code found. Readiness: N/A ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl Part No: 8E0 614 111 A Component: ABS/EDS 5.3 QUATTRO D00 Shop #: BB 24334 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: Redir Fail! Part No: 4D0 820 043 K Component: D2-KLIMAVOLLAUTOMAT D05 Coding: 00081 Shop #: WSC 02324 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: Redir Fail! Part No: 4D0 959 655 H Component: Airbag 7 Audi 050B Coding: 00225 Shop #: WSC 02324 3 Faults Found: 00656 - Seat Occupied Sensor; Passenger Side (G128) 32-10 - Resistance too High - Intermittent 01215 - Seat Occupant Sensor; Driver Side Rear (G177) 32-10 - Resistance too High - Intermittent 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4D0-919-033-MYW.lbl Part No: 4D0 919 035 G Component: D2-KOMBIINSTRUMENT D48 Coding: 00483 Shop #: WSC 02324 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Part No: 4B0 953 234 Component: IMMO AUZ9Z0V9007779 D03 Coding: 00000 Shop #: WSC 00818 No fault code found. ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels: 8D0-862-257.lbl Part No: 8LO 862 257 Component: ZV-Pumpe, DWA, Funk D03 Coding: 13130 Shop #: WSC 02324 1 Fault Found: 01370 - Alarm triggered by Interior Monitoring 35-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 8L0 951 173 Component: Innenraumueberw. D03 Coding: 00001 Shop #: WSC 00000 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8D0-035-1xx-56.lbl Part No: 4B0 035 186 Component: Radio 0001 Coding: 00207 Shop #: WSC 02324 No fault code found. ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4B0-919-283.lbl Part No: 4B0 919 283 Component: Parkingsystem A8 RDW D15 Coding: 01108 Shop #: WSC 02324 1 Fault Found: 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 37-00 - Faulty ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: 01L-927-156.lbl Part No: 4D0 927 156 AN Component: AG5 01L 4.2l4V RdW D06 Coding: 00001 Shop #: WSC 02314 1 Fault Found: 17087 - Brake Switch (F): Electrical Malfunction P0703 - 35-00 - - End --------------------------------------------------------------------- so, not bad guess as a first stab, I'm going to reset them all and see what comes back.... |
Just so you know and don't worry:
17087 is no problem - Link 01546 - Sensor for Parking Aid; Rear Mid-Left (G204) 37-00 - Faulty - Probably requires replacement (easy job) 01370 - Alarm triggered by Interior Monitoring 35-00 - Nothing to worry about. 00656 - Seat Occupied Sensor; Passenger Side (G128) 32-10 - Resistance too High - Intermittent 01215 - Seat Occupant Sensor; Driver Side Rear (G177) 32-10 - Resistance too High - Intermittent 00532 - Supply Voltage B+ 07-10 - Signal too Low - Intermittent Ian is the expert on these. 01217 is similar to 00656 and 01215 Link 00532 Link
As mentioned, I'm going to reset them all and see what comes back. I'll make note to press teh brake before runing the test ![]() |
