Just realised I was posting in wrong thread. I found the part numbers on VagCat
gearbox undertray (apparently 2 versions): 19 4D0863823BK sound deadener rear / 6 cylinder: diesel eng. (19) 4D0863823BL sound deadener rear / 8 cylinder: diesel eng. Undertray bracket (will the existing one work?) 2 4D0863844A retainer / sound deadener / otto engine (2) 4D0863844F retainer / sound deadener / also use: *>>4D-1-010000 4D0 260 778 N 901 752 03 / diesel eng. Other coverings: 20 4D0863187A cover for jointed shaft left / diesel eng. 21 4D0863188A cover for jointed shaft right / diesel eng. (21) 4D0863188C cover for jointed shaft / rework if necessary right / 8 cylinder: diesel eng. 22 4D0863197B seal (self-adhesivel) 140X37X2 / 23 4D0863200B covering / only for: right / 24 4D1864309A cover for engine compartment / tie rod left / diesel eng. (25) 4D1864310A cover for engine compartment / tie rod right / diesel eng. |
>> Weird picture of front wheel arch where we can see pastic panel completely
>> covering area which is usually open on petrol engine cars and a single hole >> for drive shaft. Will do better picture later when I remove the wheel for a need. Removed wheel today to change aircon drier and made better pictures:
I'd rather drive on left |
A complete protective surround for gearbox.
nice! ![]() |
