Old 14th October 2013, 01:19 PM
gninnam gninnam is offline
Default No Key Recognised
So - having to use the key in the ignition because when I try to use the keyless entry or start the car from the start button I get 'No Key Recognised' on the centre display.
I believe I need the update that Nigel had to get rid of his Battery is knackered prompt - could this be the cause?
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 14th October 2013, 04:11 PM
I get it now an again, usually when the battery in the key is starting to get low, more often if my phone is in that pocket.
Have you tried a new battery in the key?
Old 14th October 2013, 05:47 PM
Does it need the battery to work?
My car came with a plastic key with no battery and no remote, but it can be used for start authorisation.
Old 14th October 2013, 06:09 PM
Not changed. Does it not use the same as the plipper as that works ok?
Andy.
Current cars:
BMW i4 M-Sport
Not tried the second key...
Andy.
Current cars:
BMW i4 M-Sport
Old 14th October 2013, 06:34 PM
Probably the antennas in the centre console near the cupholder or their wiring.
It is called KESSY if I remember.
Maybe a VCDS scan will reveal a faulty antenna?
Old 14th October 2013, 06:35 PM
The plipper will work when the battery is too low for the remote key function. I usually find that it'll start giving the odd 'no key' warning when starting, then when going along randomly for a few seconds, and just gets worse until a new battery, was the same in my PF too.
Old 14th October 2013, 08:27 PM
Will try the battery change first. Cheers
Andy.
Current cars:
BMW i4 M-Sport
