Old 22nd October 2013, 06:48 AM
Nice shiny trim, have you ordered driving cloves yet to prevent fingernail scratches.
Old 22nd October 2013, 07:56 AM
Oh, I'm so tempted! Remind me of the cost again - I can't find that post. And a link for ordering please.
Old 22nd October 2013, 08:18 AM
You can get most of them from TPS still - about £80+vat from them
The drivers one came from http://trshop.audi.de
And was about £96 if I calculated my exchange rate correctly
Basically if the ones you want are available through TPS order them before they're NLA but be prepared that 1 or more might become NLA after you've ordered
This thread has the etka printouts to work out what you might want
http://forum.a8parts.co.uk/showthread.php?t=5807&page=5
Ask if not sure
Old 26th October 2013, 10:16 PM
If I could get the Mrs to wear them in the passenger seat I would lol - the door lock button on her A6 looks like somebody's taken a shotgun to it with all the nail marks!
Finally changed the driver's door trim today, dodging heavy showers while I did it....
Glad I left it till last as you've obviously got 6 different connections to remove and a lot less wiggle room for getting all the electrics out of the aperture. Unplugging everything is easy enough once you've taken a pic of which window plug goes where. Did the rest on the bench as I knew there'd be some effort to get the switches out.
Worst one to remove is the rear window lock out - fiddly as it's got clips holding the loom to the switch when you remove it and also tricky to release the tabs holding the switch in place. Ended up needing screwdriver up the short edge of the switch and you can do one side at a time to release it.
Cleaned all the switches before putting them back. Getting the panel back in was tricky with the extended leather as it makes it a tighter fit. Finally managed it and got the lower shell (still purple for now) back in place easily now I know how to do it!
Pics below
ID:	6902   Click image for larger version
ID:	6903   Click image for larger version
ID:	6904   Click image for larger version
ID:	6905   Click image for larger version
Old 27th October 2013, 05:35 AM
Looking good!
Old 27th October 2013, 07:39 AM
My plastics had little colour-coded stickers to show which socket was which.
Tight as the proverbial IIRC!
Old 27th October 2013, 09:17 AM
Mine didn't have any labels, but to be honest it was easier to snap a photo and just refer to it when putting it back together
