They usually need to be switched on, and it doesn't squirt every time, usually about 1 in 10.
On the FL D2 if the headlights are on and it's not below a temperature threshold where they might be frozen they should always operate if you hold the wash function for over a second. They fire sequentially and work just on water pressure
If I let mine run low it can take quite a few goes at operating the washers before the headlights join in again!
There are 2 pumps in the bottle for cars fitted with headlight wash and it's about 7 litres to fill i think. To get to them you'll have to remove the airbox and i took head light out to give more room, can't remember if i took the arch liner out too i think i did. Pumps come out easily as they're just a push fit in the bottle. it's not a hard job at all, replaced mine recently.
Headlights need to be on either side or main and bottle has to have so much juice in it as it shuts off headlight wash when getting low so you have more for the screen. Edit: I'm PF
1996 A8 4.2 QS. Bose, Solar roof, um...um... rally sport towbar. Now gone to a new home as the Traders 8. Bright yellow bus o love. Last edited by Dezzy; 22nd October 2013 at 04:51 PM. |
Later cars I think only have 1 pump assembly although may be 2 motors contained in it.
Yep, I've found that too!
![]() I've been informed the pump and level sender are one unit but the pump is working fine (and is an new OEM one fitted a year ago) so unless the pump packs in altogether it can stay as it is (annoying but bearable) until I get the enthusiasm to take a closer look at it.
Audi D3 S8 - 2007 - V10. B&O, Phantom Black, black and silver interior, and still completely standard with everything working as it should ![]() ![]() Audi TT - 2015 - Ultra |
Ron have you checked all the pipework between the washer bottle and the headlamp washers? from memory the same pump is used for both and the pipework just splits off and the tees and pipework is prone to either coming off or leaking which reduces the pressure to the headlamp washers and stops them coming up etc
Hi Neil, the problem isn't with the washers (windscreen and headlamps) as they're all working fine, it's a "false" low level on the bottle which is the issue. It came on a few days ago so I topped up but it didn't clear so the DIS is constantly telling me I need to add washer fluid.
You get a 2 year parts warranty from TPS so if your garage bought it from them they can get you a replacement free of charge and they bill TPS for labour
