Old 2nd November 2013, 12:37 PM
All sorted, part was £18 from Audi dealer incl. sachet of castor oil.
Left caliper on car (didn't disconnect hydraulics or electronics).
Took a while with VCDS functions to pop the piston out as the instructions from ELSAWIN didn't achieve this. Hardest part was keeping it clean inside, kept washing out with isopropy alcohol spray and brake fluid.
Took the piston into house and cleaned off the black hard deposits/corrosion with 2500 wet and dry and washing up liquid under the running warm tap.
The caliper looked fine apart from the rubber boot recess which I scraped out. The EPB thrust nut that you put back in the caliper and screw all the way back and the piston needs to be correct orientation so the thrust nut engages into it Cleaned out the caliper and fitted the oiled up new seal and then oiled up boot and fitted that to piston as per ELSA. Offered up piston and teased dust boot into it's groove. . Pushed the calliper in with caliper winding tool and dust boot pops into other groove on piston.
Refit to pads and carrier and then do a few function tests and all OK.
Bleed that corner's brake fluid thoroughly to wash out any particles and stray castor oil.
Old 7th November 2013, 05:40 PM
Duffy Duffy is offline
Good write up!
Old 16th March 2014, 08:18 PM
a8starr a8starr is offline
What is the procedure for removing a rear calliper? I hear you should use VCDS but how does this help if calliper is semi seized?
Old 16th March 2014, 08:56 PM
I heard you have to take the motor off and wind out the piston with a hex (allen key) bit on a drill or driver. The best thing to do is get a copy of the Audi ELSAwin official manual CDs from ebay.
Old 17th March 2014, 08:09 AM
It depends if it's the motor or the piston. The motor doesn't pull the piston in, so it still needs pushed back to change pads, etc.
You need VCDS (or an EPB tool) to tell the car to wind the motor in and then you can take it off just like a normal caliper (2 bolts).
Old 17th March 2014, 10:03 AM
Just taken car to garage this morning as I dont have the time to play around. Let's see what they say.
