Old 4th November 2013, 07:29 AM
Somerandomguy's Avatar
Default If only...
Indeed I have tried pressing that little button with no improvement. The display is completely blank, no radio info or even gear indicator.
Thanks again
Old 4th November 2013, 07:56 AM
Is it cold? Mine goes blank in cold weather. It's 4C outside right now and mine shows nothing.
It will be OK when it warms up.
Old 4th November 2013, 09:16 AM
It is a little cold, I have kept the cluster inside over night so will see if a warm cluster works any better.
Do you get any VCDS errors when your cluster is blank?
Old 4th November 2013, 09:32 AM
No, it's just the LCD material doesn't work properly until it's warmer.
Old 30th January 2014, 06:14 AM
Default Follow up
For the sake of completeness, I have now resolved this by replacing the cluster.
I managed to source a cluster from ebay with the same part number and swapped over the major components to diagnose that the main circuit board was kaput. Swapping this over left the cluster in component protection- not a nice thing to see, no interior lights on any panel, only the speedo dial working (a bit pointless at night as I couldn't see it anyway due to the lack of lights) and several warning light lit.
A visit to the dealers with the old and new clusters and 1.5 hours later i have a fully working cluster with the correct mileage, yay
Old 30th January 2014, 06:51 AM
mannyo mannyo is offline
Good to hear its sorted, and that its possible for a donor cluster to display the correct mileage. At least cluster swapping on the D3 is easier than the D2 it seems.
Manny
Past
Old 30th January 2014, 08:43 AM
Interesting as the clusters are not mileage correctable by the dealer unless it's up the way iirc, good that you got it sorted though.
Tags
dis
