Old 6th November 2013, 03:32 PM
Well that's my thread, but it's about RNS-D not Symphony so not sure how relevant it all is.
And I don't know the answer to:
in my case the rear shelf speakers are producing no sound at all. Are yours actually working?
Old 18th November 2013, 06:38 PM
nickid's Avatar
nickid nickid is offline
these are my rear speakers. what is this on the bottom?
Old 18th November 2013, 06:50 PM
Rear speakers are powered, have amps in them and then drive the rear door speakers. Hence lots of wires in the plugs.
Old 18th November 2013, 07:45 PM
nickid's Avatar
thanks mate, that's what I thought it might be.
I am looking at putting other speakers in to replace them with an amp, should I buy just bass speakers or normal speakers?
Old 18th November 2013, 07:57 PM
Way above my pay grade, but given that the left parcel shelf speaker and left rear door speakers are a matched unit (woofer, bass and treble?), similarly on the right, I wouldn't be changing any of it without expert car audio advice.
Old 18th November 2013, 08:54 PM
If you were going with a good set, then you could swap the lot and put a seperate sub amp, or even a completely seperate amp in, but there's a pile of wiring to sort.
Old 18th November 2013, 09:01 PM
nickid's Avatar
Going to replace them all starting with the rear ones. I have just bought an amp also to run the rear speakers, so I just need to figure out the best why to run it
