I'm not entirely convinced that the only purpose of that pump is the REST function.
Can it be a something like a "turbo timer" cooling feature that provides cooling for the hottest parts of the engine *after* the main coolant pump has stopped? It may well be that some areas of the engine need some coolant traffic after everything suddenly switches off?
I'd rather drive on left |
No, it ALWAYS goes off immediately you turn the ignition off. And it's for flow to the heater matrix, not the main radiator.
It presumably has "some" function in normal running, otherwise it would be idle in normal operation. Or maybe, just maybe, that would have created other problems/cost/complexity and it was easier to just leave it running? ![]() I think it also has a function of improving flow to the heater matrix, especially on a cold start, but even on the coldest days I didn't notice much difference when I disabled it on my PF S8. I'll find out tonight as I'll be doing a few short journeys late into the evening.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 26th November 2013 at 01:49 PM. |
Agree. Making engine dependent of electrical thing that can fail any moment won't be a nice solution.
Let us know how your 'heating experience' changes after switching off the damn thing.
The "heating experience" is fine.
![]() Did 4 short "pottering" trips of 1 to 3 miles each this evening over about 3 hours. All sticking to 30/40mph limits on very quiet roads so slow to warm up. Car hadn't been driven at all for 24 hours and starting external temp was about 5C. Didn't notice anything untoward, no cold air, no misting. On first trip there was noticeably warm air coming from the dash-top (demister) vents after a mile or so though the engine temp gauge didn't really move at all until later. On later trips the engine was not cold and the system started blowing warm air immediately. Pretty much the same as when I "killed" the pump on my PF S8 a few years back. ![]()
great, thanks.
Just a little (late) follow-up on this; today I finally investigated something that has been in the back of my mind for ages. When I had the central air intake cover off to look at my varying fan I noticed a couple of connectors in there and wondered if one might be relevant. One was for the fan (wiggling that cured my fan) but the other I didn't identify.
This made me question "Is there now a connector for the ACP somewhere else that is easy to get at?" i.e. Has it just been moved in the FL loom? It seems not, it's been eliminated compared to PF. ![]() It is presumably possible to disconnect the loom at the actual pump motor, but to get at that I think you've probably got to take the whole ECU box out. So my wire-snipping procedure is probably the easiest fix. The wiring pair from the pump joins another 3-wire set (probably for an actuator in the pump unit) then disappears between the air intake box and engine bulkhead. That 3-wire set does have a connector, as did the 2-wire pump pair PF. That 5-wire loom then reappears near the wiper motor, merges into a bigger loom then goes through into the cabin.
I have noticed my car takes an excessive amount of time to get heat through the vents after the engine is warm. I put this down to coolant flow through the engine not being overly keen on also flowing through the valve block, but the heater in mine has a bit of a mind of its own anyway so it could be something else. |
