Old 3rd December 2013, 08:35 PM
yes its easy enough, couple of bolts to undo if memory serves. i didnt have any problems when i did mine
Old 4th December 2013, 04:20 AM
sarg sarg is offline
Same battery at their sister website
http://www.eurocarparts.com/ecp/p/ac...8&0&1&cc5_1026
Permanent discount code: UKPAS25 or MGRORG25
both will get you 25% off everything, makes this battery £120.60
2002 Mark's D2 S8 FE
2000 FL D2 4.2 QS - SOLD 2011
Old 4th December 2013, 08:08 AM
gninnam gninnam is offline
Cheers - will let you know if I have any problems
Thanks (ordered now but will be useful for other folks)
Andy.
Current cars:
BMW i4 M-Sport
Peugeot 207 (the sons)
Gone but not forgotten
Old 4th December 2013, 04:20 PM
you will need to code it in, let me know when you want to do it
Old 4th December 2013, 05:51 PM
Cheers - battery should be here by Friday.
Problem is - have had the plaster cast off and put into a boot for 5 weeks so still can't drive
Andy.
Current cars:
BMW i4 M-Sport
Old 4th December 2013, 06:24 PM
no probs i can come over at some point if your stuck at home
Old 4th December 2013, 08:38 PM
Thanks
Andy.
Current cars:
BMW i4 M-Sport
Old 5th January 2014, 04:36 PM
audifin audifin is offline
Thank you 47p2 for the links - I followed your recommendation adn bought the cheapest Varta
Can anyone advise what to code in as part number and serial number. I found the instructions here http://wiki.ross-tech.com/wiki/index...ry_Replacement
So it wants 10 or 11 digits part number and 10 digits serial number. The label looks like this
Old 5th January 2014, 06:05 PM
Serial number can be anything. When I did mine, I just added one to the last digit and saved that. What was the previous battery, if it was a 110AH you may get away with leaving the part number, just select Varta from the dropdown. Just altering the serial is enough to get the battery monitor relearning parameters.
Old 6th January 2014, 10:52 AM
47p2's Avatar
47p2 47p2 is offline
Glad to have been of assistance
Nite Blue 3.0L SE Quattro
