![]() Not been around for a couple of days. Glad you got it sorted mate. Worth noting that a few others have had problems starting with battery not fully charged. It seems to have enough juice to run the starter but not fire the engine.
Glad you got it running. Watch that battery though, once you let them go down to 11.9V they are essentially damaged, lead-acid batteries dont like deep discharges.
Mine now has effectively 1/2 its original capacity or less. It will charge to 12.7 and pretend its fully charged, but as I recently read this is a surface charge which quickly drops to true voltage when you apply any small load. Mine quickly drops to 12.4 ~ 12.3V. My S8 seems to crank longer the lower the battery voltage. |
Interesting.
Went on holiday during the 'summer' and unfortunately, left a phone charger plugged into the fag lighter. This flattened the battery utterly and completely. Although it took a charge, maybe that buggered the batt? |
I just go by what I read on the web, for example:
http://www.batterystuff.com/blog/how...ry-is-bad.html Observation with my own battery, I charged it for 12 hours with a basic model Ctek charger, fresh off charger it read 12.7V. I put a 10A load on it for 10 seconds, after which it read 12.4V. That is not right if battery is ok. It should not go down to 12.4V after a 10 second 10A load. I charged it a second time for 14 hours using de-sulphation mode and the result was same as above. Apparently lead-acid batteries are not supposed to spend a long time below 12.4V, mine has and has lost capacity. http://www.tayna.co.uk/tutorials/car...ur-battery.php Last edited by Goran; 24th December 2013 at 04:51 PM. |
