Interesting.
Went on holiday during the 'summer' and unfortunately, left a phone charger plugged into the fag lighter. This flattened the battery utterly and completely. Although it took a charge, maybe that buggered the batt? |
I just go by what I read on the web, for example:
http://www.batterystuff.com/blog/how...ry-is-bad.html Observation with my own battery, I charged it for 12 hours with a basic model Ctek charger, fresh off charger it read 12.7V. I put a 10A load on it for 10 seconds, after which it read 12.4V. That is not right if battery is ok. It should not go down to 12.4V after a 10 second 10A load. I charged it a second time for 14 hours using de-sulphation mode and the result was same as above. Apparently lead-acid batteries are not supposed to spend a long time below 12.4V, mine has and has lost capacity. http://www.tayna.co.uk/tutorials/car...ur-battery.php Last edited by Goran; 24th December 2013 at 04:51 PM. |
