Old 6th January 2014, 02:28 PM
The noise could well be the auxiliary water pump.
Easy way to find out is to just press the "Rest" button when you get in the car and see if the noise starts.
I had to disconnect mine on both PF and FL S8's as they got intolerably noisy. PF is easy as it's an obvious plug, FL I had to cut a wire though there "may" be a plug somewhere to disconnect it.
