LT71141 starts life with a light brown colour. Let’s hope no one has tried adding Dexron to your transmission........
![]() Phil |
Glad to see you on here Phil!
Where is the best place to get the correct ATF and what is the part number I tried TPS and the guy was useless and tried to supply me with EP90 gear oil Cheers Dave
2002 S8 silver with black half leather 2000 d2 S8 in Racing green pearl, RS4 manual gearbox, 2003 A4 avant TDi 1997 Volvo V40 2.0T 1992 Mazda eunos v spec 1976 Reliant Kitten 1965 Porsche 911 |
I usually get mine from ‘theappledorn’ on eBay. It’s currently priced at £11.49/litre with free postage. The only alternative to Mobil ATF LT71141 is ZF Lifeguard Fluid 5 which is manufactured for ZF by Pentosin in Germany, but it’s hard to get hold of in the UK anyway.
![]() These are the only fluids you should use in your 5HP24A. Never use fluids that claim to be ‘equivalent’ or ‘recommended’ or similar wording. The friction modifier pack used in the fluid has been developed specifically to give the necessary static to dynamic friction characteristics required for the correct operation of the torque converter lock-up clutch when operating in its ‘continuous slip’ mode ![]() The ZF document TE-ML11 provides other car manufacturer part numbers for LT71141/Lifeguard Fluid 5 but I expect that all of these will be more expensive than £11.49/litre ![]() ![]() Phil |
The cheapest place I found Mobil ATF LT71141 was Opie oils. Worked out to about £9/litre when I purchased 12.
Currently driving - '99 Silver A8 D2 FL 4.2 QS Currently for work - '08 Raven Blue T5 174 |
Hi Phil,
Brown would make sense. It also means that no one has serviced that gearbox in it's lifetime! About 230K on the box! Any idea on what swapping the bodies would do or if it is possible ? Lee |
I don't know of any reason you can't put the newer valve block assembly on the older transmission. The differences between them are internal so the interface should be identical. I guess it's possible that the ECU runs a different calibration, but I doubt it.
Phil |
Old oil
![]() I swirled it arround the barrel up the sides to give an idea of colour Sump removed - Oil filter still in place ![]() Valve Body still in place ![]() Last edited by ulfilias; 14th January 2014 at 01:59 PM. |
