Old 11th January 2014, 11:54 AM
Think I have managed to find a 2120, just downloading.
Old 11th January 2014, 01:54 PM
2120 is no go either, I need 1110 and cannot find a download link anywhere.
Old 11th January 2014, 02:38 PM
http://www.ebay.de/itm/Audi-A6-A8-Q7...-/180699318880
Old 11th January 2014, 04:51 PM
Thanks Del, I've added that to my watch list. will have to wait till next month, what with the cambelt change, the compressor needing to be fixed, and in addition the alarm siren I ordered....
Old 11th January 2014, 06:29 PM
Audi should be able to source you the disks with the correct version on it, I did have a copy somewhere, but can't find it...
Old 11th January 2014, 07:35 PM
Apparently 1110 is no longer available, if I can get to that one from there I can use the 5750 discs.
Old 12th January 2014, 10:02 PM
I've found a download for 1110 but need a password to extract it - if I manage to acquire that I'll let you know. It's the 4e0906961h set
Old 15th January 2014, 10:54 PM
B17NKA B17NKA is offline
Hello
I have a 57 plate A8 3.0 Tdi,how will I find what version mine is and what benefits will I get by upgrading it ?
Cheers Andy
Old 16th January 2014, 06:57 AM
The only list of changes, I have pasted below. Its worth noting that the new 2014 NAV disk when released will require 5750 to work.
For version, depends on the version you already have. its either on the car screen, bottom right version button. or its in the systems menu under version.
New features:
Audi Parking System Plus can be retrofitted (Audible and graphic display of the screen)
DSP allows higher volume
Navi Announcements can be turned off during call
Volume of the background music during navigation announcements can be set
Height information can be displayed in the Navigationmap
Route can be followed on the chart via the MMI control
Crosshairs on input card is easier
Additional display arrows for the direction in which the POI will be looking for points of interest
Better labeling of highway exits at low zoom levels
Voice control and navigation of the top targets are immediately available
Bluetooth: access to more phonebook memory
Configurable Bluetooth PIN
If you select a POI in navigation, then you can dial the number directly.
VCS (voice control system) is available in conjunction with Hands free kit.
Sound Setup: Setting DSP Driver / Symmetric is not saved. Always remains on symmetric
On vehicles with DSP may cause a total failure of all the speakers. Ignition off for a long time to correct the problem.
DSP forgets DRIVER / SYMMETRIC setting is fixed.
Bird-view navigation menu is selectable 3D map display.
AMI (Audi Music Interface) is now upgradeable to connect IPOD, USB sticks, hard drives, etc.
MP3-CD changer support few changes are known.
Bose surround will not forget the surround setting
Trouble-free integration of the new iPod generations.
