Old 13th January 2014, 10:34 AM
As rain water scuttles from the windscreen it travels **via** Botang's hole area to those wheel arch drains. In fact, water falls from windscreen right into Botang's hole. Cleaning wheel arch drains won't save him if Botang's hole is leaking.
Old 13th January 2014, 02:01 PM
H24k H24k is offline
Default Found the problem
Thanks for all the advice guys its Greatly Appreciated, there are so many good people on this site offering advice and trying to help and Im Very Thankful,
I found the problem which was the 191 relay, and as Notorious said the water is defo going onto the relays behind the glove box, the ones behind the wooden panel seem fine but the others had water on them and the 191 flasher relay was full of water and rusted like a mo fo!! lol
So ive ordered one off ebay for a few quid and im thinking to try and cover the whole relay box with maybe a plastic bag to prevent the water going onto the relays until I can sort the drain problem out, just to prevent this happening again and also damaging more relays etc.
Old 13th January 2014, 02:08 PM
Have you not even had a quick look yet to check out ANY of the possibilities?
Old 13th January 2014, 02:09 PM
What you need to do now:
* Make sure you check **all** relays in that auxiliary plate. On later facelift cars the ABS relay is also on that plate. If it is wet you can expect all kinds of ABS problems soon. Don't try to fix wet relays -- they are kaput -- order new ones.
* Open panel under wood cover and double check there is no water there. Usually there will be no water, but just to be on safe side
* Fix the Botang's hole.
* Dry the car.
Old 13th January 2014, 02:16 PM
If you do nothing with Botang's hole the water will get to rear seats area because floor is a bit inclined and water will accumulate there. If you wait -- you can have 5+ litres easily under rear passenger feet area (I'm not joking!) since there's a lot of foam under the carpet in the rear. Removing water from there is painful (seats out and carpet out job).
Fix the hole now. Don't think of covering relay box with a bag.
Old 13th January 2014, 02:35 PM
Is Botang's Hole on PF and FL cars? I had a feeling it was just on PF models for some reason
Old 13th January 2014, 02:39 PM
It's on FL cars too. I fixed mine when it started leaking.
Old 13th January 2014, 02:40 PM
Agree except it isn't necessarily (or just) Botangs hole. The source needs to be found and dealt with- it could be the scuttle drains and/or aircon condenser, though the last one would probably come out a bit lower.
If the scuttle drains are blocked water will still get in even if Botangs hole is closed. It takes only moments to check them.
As for quantities of water I had more than 5 litres! The back nearside footwell looked like a footbath.
Old 13th January 2014, 02:41 PM
If water is dripping on indicator relay it's 100% via Botang's hole.
Can't be anything else.
Old 13th January 2014, 02:44 PM
Yes, but it could be getting there due to blocked scuttle drains.
