Old 13th January 2014, 03:07 PM
There is no doubt CTEK does good battery charges if a bit expensive but the one linked is only 5A. They do 25A workshop chargers but they are £200+.
I would recommend at least 10A for A8 http://www.ctek.com/gb/en/chargers/MXS%2010
From specs for 5A model:
Battery capacity 1.2–110Ah up to 160Ah for maintenance.
The one I linked I have had for more than a year and my battery is monstrous 110ah AGM from Varta. The 5A model will charge battery overnight and it's very compact. 10 hours is usually enough. It also knows when to stop charging, which is the most important feature. I have never fully discharged my battery, so may take longer to charge if battery is fully discharged. It is lightweight, small and has carrying bag, so I simply keep it in car all the time.
P.S. I also purchased rubber case/bumper, which is absolutely great:
http://www.ctek.com/gb/en/chargers/Bumper
Old 13th January 2014, 07:59 PM
Pictures Jim. Apologies for bad lighting -- I had to use small flashlight.
ID:	7171   Click image for larger version
ID:	7172   Click image for larger version
ID:	7173   Click image for larger version
ID:	7174   Click image for larger version
ID:	7175   Click image for larger version
ID:	7176   Click image for larger version
ID:	7177   Click image for larger version
Old 14th January 2014, 07:40 AM
Dave McB Dave McB is offline
I have a Ctek trickle charger on my cosworth - no complaints at all.
Theres a few cheaper alternatives about nowadays that do the same job tho. The Ctek has never let me down.
And your battery should be around 100/110aH
Old 14th January 2014, 12:08 PM
Thanks Sergey, that's pretty neat!
Old 14th January 2014, 07:40 PM
It's funny I was looking at chargers yesterday and came across them and was wondering about asking them about a group buy if there was enough interest from the folks on here.
I would be looking to get the 25 amp one so you could power the car during updates etc without daring the battery.
