Old 16th January 2014, 10:53 PM
2 bolts to release the switch surround
I knew I forgot something, they're pretty self-evident.
Old 17th January 2014, 08:20 AM
I know - main reason for reposting the info is I checked Elsawin to confirm which end you pry from as I know the fronts are one way and the rears are the other. Fortunately it gives you a diagram as there's potential to do damage working from the wrong side
Old 17th January 2014, 06:08 PM
Condor Condor is offline
Thanks again, will see if I get an opportunity this weekend.
