D2 - Lights Headlights, xenons, foglights. Everything outside the car that glows |
Indeed. It was definitely being "detected" as open, but was mostly physically locked along with the car. Until this weekend when it would often bounce open again if closed gently.
I now think that the interior mechanism was probably getting stuck in some interim position whereby it was physically just latched but the part of the mechanism that presses on and closes the microswitch hadn't moved far enough. Now it's been WD40'ed it also makes a much more positive sound when unlocking as well - a very positive sliding latch sound.
I am having the same intermittent indication problem with the passenger door switch. The door/car can be be locked but the lights dont flash and the interior lights do not fade out. It usually requires slamming the door hard. On Sunday The Laird kindly lent me his garage to do some small jobs (on my car, not his
Sometimes wd40 will make it worse especially if there's gunk in there already as it turns it to an emulsion. Gt85 can be a slightly better choice for a spray and hope treatment
Thanks Adrian, WD40 is often considered as a miracle cure for everything but I guess it is primarily a water displacement fluid and lubricant. GT 85 seems to be much the same - though with added PTFE. See this taken from their site "We have protected our hardwood patio furniture, killed woodworm with it and even eased up old granny’s joints! "
The reason I mention it is I race toy cars offroad (1/8th scale buggies) and if you spray WD40 on them in an attempt to clean them or keep mud/dust off it will do precisely the reverse.
GT85 can be sprayed on, left to dry a bit and blasted off with an airline if needed and it will stop crud sticking to the car as badly. It's great for making plastics come up like new as well ![]()
Yes, I noted that with GT85 it dries off leaving a PTFE coating. Sounds good, so I intend to give it a go. Might try it on my joints too!
Is that microswitch connected when boot is open or when it's closed?
This afternoon, to answer ainars question I had a close look at the spare latch I have - bought from A8parts last week. I realised that it was rattling and looking closely I could see (through the hole where the release lever is) a piece of plastic moving around apparently not located onto anything. So I popped the cover open and lifted the microswitch out, to find a small thin curved piece of nylon/plastic about 15mm by 5mm which just fell out. Looking inside there's a long piece of the same plastic across the latch that is clearly part of the mechanism and which at the very least moves the microswitch lever. The broken bit appeared to have come from one end, so I'm guessing it would not always work exactly as intended as it was loose and poorly located. If the switch on my car has similar damage and loose bits in the mechanism that could explain the various failures, including non-detection of closure and not latching at all. I've dropped A8parts an email with a photo of the parts; presumably they will be able to replace it easily enough. ![]()
![]() Just swapped the latch over, actually leaving the existing microswitch in place - it was easier that way and it looked and worked perfectly fine. The old latch has the same plastic piece inside, though it was made of dark purple-blue plastic not cloudy white nylon. And it was broken in exactly the same way. So, clearly a design weakness. ![]() Looking at the way the latch is mounted it has space around it for water to drain out and the microswitch is "high and dry". So I think I just had the broken plastic problem, the water ingress was a red herring. So, something for people to look out for. If your boot latch starts misbehaving it could just be a tiny piece of broken plastic inside. You can, if you look very carefully, actually see the plastic piece by looking at the latch mounted on the car with a torch. If it's not visible it's broken off and you have, or will probably have, a problem. I'll try to post a photo if I can, but that may be difficult, so I'll describe it: Open the boot, and with a bright light look closely at the latch in the lid, from end-on. You should just be able to peer down the crack between the plastic latch cover and the boot lid metalwork on what (with the boot open) will be the underside (i.e. inside). Slightly offset to the offside (towards the lock) you will see a yellowish metal arm (approx. 5mm wide) protruding from a slot in the latch body. This arm has the lock release cable attached to it, though that won't be visible. If you operate the unlock button (e.g. on your remote) it will move slightly. Through the open (lock) side of that slot you should see a small piece of plastic extending right across, at a bit of an angle. It also flexes very slightly when the arm moves. If it's not there or appears loose that's your problem. But it is a very narrow gap so you might not see anything and need to dismantle it to check.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 25th January 2014 at 12:21 PM. |
Just a (hopefully) final observation if you think you have this problem.
If you take the latch off the car and shake out the broken piece (which mainly causes problems by obstructing the mechanism) it is likely to work OK as long as it's all clean and well-lubricated. ![]() The piece that breaks off is a sort of "return spring" but there is also a metal spring (on the metal release arm) that supplements it indirectly, along with gravity and the spring arm on the microswitch. So the plastic piece that triggers the microswitch would normally stay in the right place, though it is not as positively located.
