#41
Interestingly, over the weekend, when it got a bit colder, I found the boot more difficult to shut. At times it needed a really good slam or it didn't latch properly.
This made me wonder whether the mechanism is "gunged up" with emulsified grease and that is what's really at the heart of the problem. Having looked inside there are small moving plastic parts around the switch that could be easily impeded. So this morning I gave the latch some serious and copious attention from the WD40 can. In the middle of squirting it in I heard a tiny movement inside the latch and a chirp from the alarm horn. It now appears to be working perfectly in all respects, closing and opening smoothly and easily, chirping and flashing the lights. Now, to follow the old adage, I just need to find something I can fix with duct tape. (TBH I used some earlier, on the other car ![]()
#42
That's an interesting observation - I've noticed in the past when locking the car away in the garage that if I lock the car with the boot open (usually closing the windows on the remote but haven't finished retrieving stuff from the boot) I don't get the flash of lights UNTIL the boot lid is shut, so it does suggest the boot was either failing to lock properly or giving the appearance to the control module that it wasn't properly shut
#43
Indeed. It was definitely being "detected" as open, but was mostly physically locked along with the car. Until this weekend when it would often bounce open again if closed gently.
I now think that the interior mechanism was probably getting stuck in some interim position whereby it was physically just latched but the part of the mechanism that presses on and closes the microswitch hadn't moved far enough. Now it's been WD40'ed it also makes a much more positive sound when unlocking as well - a very positive sliding latch sound.
#44
I am having the same intermittent indication problem with the passenger door switch. The door/car can be be locked but the lights dont flash and the interior lights do not fade out. It usually requires slamming the door hard. On Sunday The Laird kindly lent me his garage to do some small jobs (on my car, not his
#45
Sometimes wd40 will make it worse especially if there's gunk in there already as it turns it to an emulsion. Gt85 can be a slightly better choice for a spray and hope treatment
#46
Thanks Adrian, WD40 is often considered as a miracle cure for everything but I guess it is primarily a water displacement fluid and lubricant. GT 85 seems to be much the same - though with added PTFE. See this taken from their site "We have protected our hardwood patio furniture, killed woodworm with it and even eased up old granny’s joints! "
#47
The reason I mention it is I race toy cars offroad (1/8th scale buggies) and if you spray WD40 on them in an attempt to clean them or keep mud/dust off it will do precisely the reverse.
GT85 can be sprayed on, left to dry a bit and blasted off with an airline if needed and it will stop crud sticking to the car as badly. It's great for making plastics come up like new as well ![]()
#48
Yes, I noted that with GT85 it dries off leaving a PTFE coating. Sounds good, so I intend to give it a go. Might try it on my joints too!
#49
Is that microswitch connected when boot is open or when it's closed?
#50
Give me 5 minutes and I'll tell you....
Edit: Circuit closed when boot is open. And to elaborate, that is with no pressure on the switch, i.e. the microswitch is NC. Closing the boot latch applies pressure on the microswitch, opening the circuit.
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 21st January 2014 at 02:15 PM. |
