Old 28th January 2014, 05:15 PM
mannyo mannyo is offline
Mines been fine for 300 miles, until today. I have air escaping from the compressor area, as the compressor starts and stops I can here PSSHHHHT a bit like when you remove a tyre pump from a valve.
I think it only does this as the compressor starts and stops although not sure, at first I thought it may have been a HGV behind me but it did it again on the way home from work.
Could be air escaping from the output air line, or something else. Everything is still working, no fault codes. I'll give the mechanic a call tomorrow I guess.
Manny
Past
Old 28th January 2014, 08:14 PM
A8 Doc A8 Doc is offline
Probably just an airlock somewhere? The compressor might auto bleed?
Old 29th January 2014, 12:38 PM
The mechanic is popping by my workplace on his way to work tomorrow to have a listen and take the car if he thinks something is wrong. I hope the sound can be replicated on demand.
Manny
Past
Old 29th January 2014, 05:44 PM
To confirm, I can replicate it on demand, it appears to be as the compressor shuts off. If I sit in the car and select Lift, so the car uses the air in the tank, then select Dynamic so the car dumps all the air from the struts. Finally select Lift again, so the compressor must run to get pressure back. After the car has raised and the pressure tank is full, the compressor cuts out but just as it stops there is a psssht sound lasting just a fraction of a second. Does it every time, so I can show him tomorrow morning.
The sound maybe normal, but I can't say I have noticed it before.
Manny
Past
Old 30th January 2014, 06:48 AM
He has been, and has taken the car back to the workshop. He is happy that something is not right, so will once again gain access to the compressor. Compressor is working fine, but air is escaping from the compressor area when its running.
Manny
Past
Old 30th January 2014, 07:42 AM
Maybe it is purging/regenerating the air-dryer?
"The appropriate valves 9a, 9b and 9c, 9d and the electrical exhaust solenoid valve 5 are opened. The air can flow through the exhaust solenoid 5 to open the pneumatic, pilot operated exhaust solenoid 6.
The air leaves the system via exhaust solenoid 6, additional silencer 7 and air filter 8. When air flows through the air drier 2, the desiccant is regenerated."
Old 30th January 2014, 10:14 AM
The sound is quiet loud though, I am sure it must do this in normal operation, pehaps damped by something. I could here it pssshhht as he drove out the car park.
He did the repair last Tuesday, and it was silent on till Sunday night having driven the car for around 5 hours in total during the weekend.
Manny
Past
