Old 30th January 2014, 06:23 PM
Will post them 1st class tomorrow, but you know what.
I'm thinking if you won't need a 10w resistor like used on 501 side lights to stop the errors.
This type, but one per pair
first two from the top left
http://www.hids-direct.co.uk/categor...resistor-fixes
Aren't they P21W bulbs ??
Do you get errors on the dash when lights on and not functioning properly (2 on and 2 off bulbs) ??
I'm sure is doable to do the whole rear in leds.
Only issue with bigger resistors is the obvious heat (orange ones from the link, even 10w), the small one I'm sending you still generate heat but not on the level that needs a heatsink.
