![]() But as always I've got few questions: 30sec, is that till the white arrow up disappears or until car stops lifting?? Was that during the drive or on the driveway before you went to work this morning?? 1.22sec feels like a long time in my example but even if car stopped lifting (got to the Lift mode) the arrow stayed white for good 20sec + This could be with car being on a slight slope and control unit was just trying to get it as level as possible??? Waiting for your pressure update later on ![]() Cheers Manny ![]()
Just a quick update to what I just find out.
I spoke to best Master Technician I know from Audi and what this fella says about the pressure in that video seems to be a bit of b@l@x and is misleading. 16 bar he says=220PSI Front tyre with max load=41PSI That is a 5,5 times higher pressure than in a tyre !!!!! Have you seen the air hoses on the the compressor side, even he said this would be unreal cos even on a new compressor you would be able to hold the pressure with your finger if you unclip the hose because what he says that there is an operating pressure of around 6bar when no leaks !!!!! 6bar seems to be more real than 16bar, but I couldn't really talk to him for long so I didn't asked all the questions and we didnt managed to check the pressure against any document which would give me something to compare my readings to. Interesting Manny's and Delboy's pressure readings should make it more clear, especially Manny's after recent fix. Cheers boys ![]()
Those figures around 3 or 4 bar shown on screen seem entirely plausible.
You could do some "ball-park" calculations based on the size of the units and weight of the car as a cross-check. ![]() e.g. 3 bar is 3*10**5 N/m**2 (30 Newtons per square cm) A 2 tonne car on Earths surface will apply a force of about 5000 N on each corner, which at 3 bar needs about 156 sq cm. If that was a disc it would be about 7cm radius, or 5.5" diameter. How does that match the lifting struts?
2003 D2 FL S8. Irish Green Pearl/Beige. Solar sunroof, auto-dim mirrors, electric rear seat functions and extended leather. Ski hatch retrofit. Aftermarket reversing camera. DVB-T and XCarlink now removed as redundant. 2016 Volvo V40 T5 Cross Country (4WD) with ALL the toys including adaptive cruise etc. etc. Osmium Grey with Blonde/Charcoal leather interior. Polestar performance "optimisation". ![]() ![]() Finally: gone, but not forgotten..... 1998 D2 PF S8. Agate Grey/Platinum. Every option (I think) except electric rear seats, Tiptronic steering wheel, ski hatch, towbar & dimming door mirrors. e.g. Cruise control, NavPlus/TV, Bose, GSM, Xenons, Solar roof, Parking sensors, Alcantara/leather everywhere of course. ![]() 1998 (very early) Ford Focus 1.8 Zetec; ABS/TCS, Heated screen/mirrors, Aircon. Added Auto-dim mirror, Leather seats, Trip computer, Cruise control, OEM Ford SatNav with CD changer. And before that a lot of Rover 800s, a few oddities, a lovely Triumph Dolomite 1850HL with Overdrive and way back in my schooldays an Austin Seven aka Mini 850! Last edited by HPsauce; 31st January 2014 at 12:21 PM. |
Thats funny, just found this info in SSP292:
but this I understand is pressure value inside the springs, can you measure pressure on each spring??? I switched through all the channels yesterday and there was no group for individual springs ''Each suspension strut features residual pressure retaining valves directly at the air connection. This ensures that a minimum pressure of approx. 3.5 bar is maintained in the pneumatic springs. This practically eliminates the risk of damage during storage and assembly to the greatest possible extent.'' Another interesting thing about the accumulator pressure of 16bars not the compressor pressure: ''Accumulator The accumulator is situated between the floor of the boot and the rear silencer on the left-hand side of the vehicle. Construction: The accumulator is made of aluminium. It has a volume of 5.8l and a max. operating pressure of 16 bar. Function: The objective in designing this system was to reliably satisfy functional requirements whilst keeping energy consumption to a minimum (so that the compressor is on as little as possible). In order to enable controlled pressure build-up to be effected solely with the accumulator, there must be a minimum difference in pressure of 3 bar between the accumulator and the pneumatic springs'' >>>>>> Final control diagnosis Final control diagnosis checks the function of the compressor, the solenoid valves and the struts/shock absorbers. Diagnosis is executed automatically in three steps. 1. Test of each individual strut by lowering it 20 mm below its current level for a period of 30 seconds 2. Charge and empty the accumulator 3. Variation of electrical currents to actuate the shock absorbers Final control diagnosis is implemented when the vehicle is stationary and the ignition is on. The engine may be running. During final control diagnosis, the yellow warning lamp in the dash panel insert flashes.
Have not seen the air pipes on D3 but brake pipes and hoses(any car) do not look too impressive however they can handle 150-200 Bar.
I'll see what I can do this evening, the compressor outputs 16bar and that fills up the pressure resevoir, in turn that supplies the valve block, which feeds all four struts. So the 16 bar is used to maintain all four struts, thats only 4 bar each. The actual air needed will be less otherwise the compressor will be running pretty much all the time. I would expect to see close to 16bar at the G291 sensor, but maybe I'll be proved wrong.
Right I did some testing in the office carpark before driving home.
Starting point, car has been parked all day and compressor has not yet run. Reading Down to Dynamic Reading Up to Lift In Motion, compressor on. Fully Lifted If you view the attached VCDS log which I did driving home from work, you can see that the sensor does ramp up to in excess of 10 bar.
Manny 2004 A4 1.8T Sport Cabriolet, 89K Miles Past 2004 D3 A8 3.7 Quattro, Xenon, Bose, Blinds, Solar Sunroof, TV, ACC, phone and almost every option. 168K miles rising slowly with retrofit AMI and DVB-T in place of Analogue 2003 Volvo S60 D5 SE Manual, 197K miles. 2001 D2 A8 3.7 QS, Bi-Xenon, Bose, Blinds, Electric Everything, retrofitted RNS-D, 191K Miles Last edited by mannyo; 31st January 2014 at 05:46 PM. |
Hi Mannyo,
Pressure in the Accumulator is available to any / all the struts, its not divided by 4. Each Strut has a solenoid valve dedicated to it that opens in conjunction with the valve that isolates the accumulator. I went out just now and tested mine, and using measuring bocks in VCDS I could see between 3 - 9 bar depending on if i was going up or down. I did my first set of tests using the mmi to raise and lower the car with the engine off, the compressor would not run and after 4/5 up down sequences the accumulator emptied and lift was greyed out on the mmi. Once started the compressor ran and charged back up. All that said I found there is a better way to test and that's to go to output tests in the level control module and run them, it will go through many tests but the one that we should pay particular attention to is Accumulator test. Unfortunately I didn't let mine run long enough and it didn't charge high enough to satisfy the test. I will do another test tomorrow as the compressor was up to around 60 degrees after all my dicking around.
Del ![]() Last edited by Delboy; 31st January 2014 at 05:42 PM. |
Del,
I have just attached an excel spreadsheet to post 53, which is a log of the suspension activity on my drive home.
