Old 18th August 2009, 03:27 PM
ChriS8 ChriS8 is offline
Clive, don't you trust in the forum ?
Sure, there is a solution, but only for the VAG garages themselves.
The program is called ELSA Win, but it's forbidden to show to costumers and also to use it as a private worker.
But anyway 50% of interested Audidrivers have it
Here are some pics.
It's located right there under the cover (couldn't find a matching pic, so I had to take an internet pic)
If you remove the air intake tube you can see the sensor.
You will have to remove a plastic clip which is shoved in. (not on the pic)
This is the part seperated.
The sensor is only plugged in, so you can pull it apart.
You will find there a small amount of cooling water, which needs to be cold, so you can work properly. So let your engine cool down some hours.
Greetz and good luck,
Chris.
Now playing: Goldfinger - Get Up
via FoxyTunes
Audi S8 manual, 1996 <- much fun
Kawasaki ZX9-R 2001 <- much more fun
always remember:ficken!
Old 18th August 2009, 03:37 PM
CliveH's Avatar
CliveH CliveH is offline
Yes, of course! was just hoping there might be a similar publication that we could refer to.
Anyway, excellent write-up and what are those thingies going into each bank of your engine...??
Present: S4 B8 avant, fully loaded, MRC Stage2, Milltek non-res, KW springs
Past: S8 D2 FL, S2 ABY coupe, RS6 C5 saloon, RS4 B7 saloon, S4 B5 saloon, S4 B6 avant, all gone but not forgotten
Old 18th August 2009, 03:41 PM
Hi.
No one of these pix shows my own car
It's the car of a friend of mine, where I changed the part.
The first pic shows a 3.7 fitted with LPG-injectors.
On the other pics you see those ribbed tubes are also LPG-tubes to make it sniffing liquid gas
Now playing: Goldfinger - Spokesman
via FoxyTunes
