Old 10th February 2014, 10:32 PM
Conquistador's Avatar
Default Best £6 I've spent in a long time...
As I can't (at the moment) justify buying a full fat version of the Ross-Tech gear that many people seem to use, I bought this little gadget on a recommendation from a friend that works for Halfrauds...
It's an OBDII Bluetooth diagnostic reader. The number of settings and menus to play with is endless
Gives live running fugures:
Your current position with Google maps:
Not played with it enough to look at any fault codes or service lights it might display but it lets you do most things.
Currently '8-less
Previously:
- D3 A8 3.0 CVT
- D3 3.7 V8
Old 11th February 2014, 05:27 AM
Torque is a great wee app, enjoy fella.
Old 11th February 2014, 03:02 PM
CliveH's Avatar
CliveH CliveH is offline
Looks good. Is there an iOS version available?
Old 11th February 2014, 05:01 PM
Torque is not available as an iOS app, but there is another simillar app called "Dash Command". it does require a different OBD dongle though, one that connects using Wifi rather than bluetooth.
http://www.palmerperformance.com/pro...hone/index.php
I have had similar dongle with Torque for several years now and I did pay a bit more for it then. It's a great little gadget and worth every penny but it will only communicate with engine ECU and read generic OBD II codes and data. No connection to other control units and no support for make specific data.
Old 12th March 2014, 09:50 PM
http://www.aliexpress.com/item/2014-...074015606.html
Wow £4.50 here!
