Old 11th February 2014, 11:05 PM
Reversing camera was a later addition to everything, its quite rare to see prefacelift other than some S8's.
The DVD player would go where your DAB module is, although I dont know where the dAB module ends up after that. It does get a bit packed in there !
I dont know where the reverse camera modules sits, but I'll take a peek at mine tomorrow if I get chance to see if its obvious
Old 12th February 2014, 07:26 AM
Thanks Ian, are you talking about the nav DVD goes in place of dab?
Honestly it's got me puzzled as I have the both the media rack with all the modules and the nav drive rack in the house and the rvc doesn't seem to line up with any of the bolts?
Old 12th February 2014, 08:28 AM
Nope.. a 'proper' DVD player for watching films.. Honestly, I don't know how they worked out where all the crap goes, and all the wiring combos
Old 12th February 2014, 08:37 AM
I aint got one of those, I had a cko 6 disc dvd changer hanging under the parcel shelf. (GONE)
Old 12th February 2014, 08:35 AM
Er, I didnt think this all the way through..... Dave has my S8 at the mo, and I have his W12 and he has no reverse cam, so I cant really help at the mo.....
Old 12th February 2014, 01:38 PM
Ok no worries, If you could have a nose around when you get her back would be much appreciated.
Work on that front has came to a stop and now I have the rear seats parcel shelf etc out to determine the moisture in back window.
Any one fancy buying a stripped out S8 ???
Old 12th February 2014, 04:41 PM
Do you need RVC if you have analogue TV?
I'm sure I read you don't but can't remember where and no nothing else about doing this so take with a pinch of salt.
I think I read on USA forums that they need RVC because they don't have TV module like over in Europe.
***EDIT yes delboy thanks, I remember it is if you don't have TV, you need a new higher-spec MMI head unit as there is no video in on these models..
Old 12th February 2014, 06:29 PM
The RVC module has a few functions, its purpose is to act as a video switch interrupting the TV signal, and routing the camera signal to the mmi display.
It also generates the bendy guide lines by processing the steering angle info on the can bus, and overlaying this info on top of the camera video signal
