D2 - Wheels and Tyres Refurbing, center caps, tyre brands, tyrefitters - discuss it here |
My feeling is it probably the control arm bushings starting to wear allow the weal to lean inwards slightly and over time its having an effect. Don't think i can be arsed to rebush it though but maybe i will if they not too pricey.
Im going to get it aligned again just to be sure something is not amiss on the toe out which could effect fronts as i did think both looked a wee bit toe out from standing at the front of it although thought it was just my eyes but now thinging perhaps i was correct, needs further investigation. Last edited by brasiliangringo; 15th February 2014 at 03:27 PM. |
I can say with certainty the front are both wearing on the inside shoulder. Rears are to slightly but i believe rear camber can be adjusted. Alignment aint my thing as dont have a machine to do it.
Fronts will wear more as these cars do have a tendency to scrub quite a bit on tight corners and car park manoeuvring.
Yep but its specifically inside shoulder wear on both that wouldn't be accounted for by that.
Could be down to suspension component wear or incorrect alignment.
When doing alignment make sure they do 'constant S' correctly as well. Most garages around here do not even know what it means when you ask them to make sure it's done. Not doing it correctly is a cause of tyre wear on many A4's, A's,A8s and Passat's.
Constant S ? I'm not familiar, thanks.
