Old 18th February 2014, 07:26 PM
Look at this
Scan Before clearing all DTCs and After (Sunday 16/02/2014)
New Telephone module and Airbag wasn't fitted/fixed yet at that point
Old 18th February 2014, 07:39 PM
I'm going to do AS again, will clear the DTCs, will take it for a spin around car park and do AS again.
I'll be back in 15-20min
Old 18th February 2014, 08:02 PM
Done, see attached
So, MIC still not working same as Voice Control
Old 18th February 2014, 08:11 PM
Doesn't read so bad now does it, ok what pr code do you have for your telephone in the car? mines 9zf
Old 18th February 2014, 08:18 PM
Interestingly I looked at my coding for (77) and its different to yours mine is 0010900 which decodes as follows
00?0xx0: MMI System
1 = MMI/Sound System High
00x0?x0: Installation List
9 = Vehicle with MOST-Databus
00x0x?0: Voice Control Language
0 = Voice Control OFF
Now Voice control off has me asking what does that refer too as my car has the speech crap where you talk to it likr call so and so or navigation etc etc and it all works with that coding.
Either its a typo on ross tech or it is referring to something else.
Old 18th February 2014, 08:28 PM
That is weird
I was trying with VC off 0 and VC on 2, it won't work at all where it used to work before MMI update and loosing 77 completely.
I looked at mine PR sticker and after decoding all PR codes non of them relates to Phone.
I assume you have your PR code from the Audi's print out ??
I attached the picture of the replacement module I installed yesterday.
A copy of the one I f***ed (2nd picture)
BUT as mentioned before, the SW in VCDS is shown as bla bla bla M where sticker says SW bla bla bla F, which is what I had before messing it all up
ID:	7380   Click image for larger version
Name:	old phone.jpg
Old 18th February 2014, 08:33 PM
So have you tried the same coding as mine, do you want me to go check the adaptation values?
