Old 24th August 2009, 09:40 AM
ulfilias ulfilias is offline
Hi Conan,
Oooh. Please do. It would be nice to show that that haven't even done thier job properly by AUDIs standards.
Ta,
Lee
Old 24th August 2009, 10:11 AM
Ere Tis,
Requirements for test:
Battery voltage not less than 12.7 V
Fuse S1 OK (in fuse box, blue fuse carrier ST4)
Fuel pump relay OK (on central electrics unit in electronics box; passenger's footwell, relay position 6).
Testing:
Fuel filter OK
Ignition switched off
Checking voltage supply
Remove fuse holder cover in driver’s footwell
Pull fuse No. S1 out of fuse carrier ST4 in fuse box.
ST4 - blue fuse carrier
Connect jumper lead with momentary switch to lower terminal of socket for fuse No. S1 in fuse carrier ST4 -arrow 1-.
Connect clamp to positive battery supply (e.g. socket of 60 Amp fuse -arrow 2- at top of fuse box).
Press remote control switch.
Pump should start running audibly.
Note:
The fuel pump runs very quietly. Where possible, avoid noisy surroundings for this test. If necessary, perform the test with a 2nd mechanic.
If pump does not start running:
Remove cover for fuel gauge sender and fuel delivery unit (right side) under floor covering in boot -arrows-.
Release 4-pin connector -arrow- and unplug.
Connect multimeter (voltage range) between contacts 1 and 4 of connector.
Specification: approx. battery voltage
If the specification is not obtained:
Locate and eliminate open circuit using current flow diagram:
If the specification is obtained, even though the fuel pump did not run:
Remove fuel delivery unit
Check if the electric wires between flange and fuel pump are disconnected or broken (test continuity).
If no fault is detected in the wiring:
Fuel pump is defective. Renew fuel delivery.
Testing current draw
Test requirement:
Supply voltage for fuel pump OK
Connect clamp to positive battery supply (e.g. socket of 60 A fuse -arrow 2- at top of fuse box).
Connect multimeter with current clamp to connecting lead for remote control switch.
Measure the current draw of the fuel pump.
Specification: approx 8 A
If the specification is not attained:
Note:
If the indicated current draw is 4 amps, this means the fuel pump is running dry (without fuel).
Meter reading---------------- Cause of fault------------------------------------- Rectification
approx. 4 A -------------------- Tank empty --------------------------------------- Fill up with fuel
------------------------------------ Fuel delivery unit incorrectly installed ---- Check installation of fuel delivery unit
----------------------------------- Baffle housing leaking -------------------------- Perform leak test on baffle housing
------------------------------------ Fuel gauge sender 2 incorrectly installed - Check installation of fuel gauge sender 2
0 A ------------------------------- Fuel pump defective -------------------------- Renew fuel delivery unit
